KIVIKORSTNASSE METALLTORU.
CAPS LOCK
Lugemata postitus Postitas CAPS LOCK »
KAS KEEGI OSKAB JUHATADA KUHU PEAKS PÖÖRDUMA SELLISE HAPPEKINDLA TORU HANKIMISEKS.KAVATSEN PANNA PUUDEGA KÖETAVA KATLA JA SIIS VAJA SEE TORU SINNA SISSE AJADA.JA TEGELIKULT EI KUJUTA MA DA VEEL ETTE KUIDAS SEDA TÖÖD LÄBI VIIA.KAS KELLELGI ON SOOVITUSI.
happekindel
Re: KIVIKORSTNASSE METALLTORU.
Lugemata postitus Postitas happekindel »
pole seal hullu midagi saame hakkama küll anna oma katla ja lõõri mõõdud ja paneme paikaCAPS LOCK kirjutas:KAS KEEGI OSKAB JUHATADA KUHU PEAKS PÖÖRDUMA SELLISE HAPPEKINDLA TORU HANKIMISEKS.KAVATSEN PANNA PUUDEGA KÖETAVA KATLA JA SIIS VAJA SEE TORU SINNA SISSE AJADA.JA TEGELIKULT EI KUJUTA MA DA VEEL ETTE KUIDAS SEDA TÖÖD LÄBI VIIA.KAS KELLELGI ON SOOVITUSI.
