KIVIKORSTNASSE METALLTORU.
CAPS LOCK
Postitus Postitas CAPS LOCK »
KAS KEEGI OSKAB JUHATADA KUHU PEAKS PÖÖRDUMA SELLISE HAPPEKINDLA TORU HANKIMISEKS.KAVATSEN PANNA PUUDEGA KÖETAVA KATLA JA SIIS VAJA SEE TORU SINNA SISSE AJADA.JA TEGELIKULT EI KUJUTA MA DA VEEL ETTE KUIDAS SEDA TÖÖD LÄBI VIIA.KAS KELLELGI ON SOOVITUSI.
happekindel
Re: KIVIKORSTNASSE METALLTORU.
Postitus Postitas happekindel »
CAPS LOCK kirjutas:KAS KEEGI OSKAB JUHATADA KUHU PEAKS PÖÖRDUMA SELLISE HAPPEKINDLA TORU HANKIMISEKS.KAVATSEN PANNA PUUDEGA KÖETAVA KATLA JA SIIS VAJA SEE TORU SINNA SISSE AJADA.JA TEGELIKULT EI KUJUTA MA DA VEEL ETTE KUIDAS SEDA TÖÖD LÄBI VIIA.KAS KELLELGI ON SOOVITUSI.
pole seal hullu midagi saame hakkama küll anna oma katla ja lõõri mõõdud ja paneme paika
