Tehnilised andmed:
Müüa Süvaveepump Grundfos SQ2-55. Pump kasutamata, garantii ei kehti.
Port discharge connection: Rp 1 1 / 4
Minimum well diameter: 76 mm
Type of engine: MS3
Power consumption P1: 1.02 kW
Rated motor power P2: 0.7 kW
Frequency: 50 Hz
Rated voltage: 1 x 200-240 V
Starting method: direct
Rated current: 5.2 A
Power factor: 1,0 0
Nominal speed: 10700 rpm
Degree of protection (IEC 34-5 ): 68
Insulation class (IEC 85): F
Hinnaks sooviks 500 eurot.
Kontakt: illimar9@hot.ee
M: Süvaveepump Grundfos SQ2-55.
Külaline.
Illimar.
Külaline.
Illimar.
Re: M: Süvaveepump Grundfos SQ2-55.
Sellise hinnaga ilma garantiita käest kätte osta .... miks? Kui saab ka http://www.ehituskaup24.ee/vmchk/Veevar ... 2-55-065kW
Aga pole ju väitnud kuskil, et hind kivist on.
Pump kinnisises pakendis ja nagu mainitud juba ennem, siis garantiid ei ole.
