M: Shentai päikeseboileri komplekt, 240l
Postitatud: 12 Nov 2012, 23:06
Postitas xjan
Shentai vabavoolu päikesboileri komplekt, 240l + 24 vaakumtoruga kollektor + metallraam jms juurdekuuluv. Sobilik sooja vee tootmiseks maakodus/suvilas või täiendustega/ümberehitustega ka keerulisemates süsteemides, basseini kütteks, vms juhtudel. Võimalik lisada el. küttekeha.
PILT 2 PILT 3 PILT 4
Lisainfo: [td]Because of the larger proportion of hot water than cold water, cold water flows downward and hot water goes upward. The water will be heated continuous between water tank and vacuum tube. In other wards, hot water always floats on cold water. The hot water flows to the water tank from the vacuum tubes. Because of the proportion, cold water flows to vacuum tubes from the water tank. The cold water is heated in vacuum tubes. After it becomes hot water, it flows to water tank again. The water circulates constantly between water tank and vacuum tubes; the cold water in water tank will be hotter and hotter. Finally, all cold water will be heated to be hot water. This is the heating course of cold water.[/td][td][url=http://majasaaga.planet.ee/solar/skeem.jpg][img]http://majasaaga.planet.ee/solar/skeem_v.jpg[/img][/url][/td]
Heater:
Inner tank, the acid-resistant SUS 304-2b / stainless steel 0.4 mm.
Outer Tank coated with PVDF 0.4 mm. Insulation 50 mm polyurethane foam.
Vacuum tubes: thickness 58 mm x length 1800 mm. Diameter - vacuum tube 58 mm outside and 47 mm inside.
Metal mount, can be installed on both flat and slanted roofs.
CE certificate included.
[td]Model ST24-180 Vacuum tubes Ø 58x1800*24Pc Capacity (Liter/Day/60°C) 240l Absorber area 2.98m2 Size: A 206, B 186, C 155, D 160, E 201[/td] [td][img]http://majasaaga.planet.ee/solar/sizes.jpg[/img][/td]
Komplekt asub Murastes, Harjumaal.
yksxjan@hot.ee / 56561000
Hind: tee oma pakkumine!
Re: M: Shentai päikeseboileri komplekt, 240l
Postitatud: 13 Nov 2012, 16:53
Postitas rein113
Ma küsin siin, et kõik infi saaksid.
Kas seade on uus või kasutatud?
Saan aru, et tegu on ujukklapiga ja survevaba mahutiga. Kuidas saab sellisest paagist sooja vee ühendada segistisse, kuhu tuleb sisse ka trassisurvega külm vesi, nagu on näidatud ülaltoodud skeemil, minu meelest ei saa ilma surveta soe vesi seal õigesti seguneda?
Postitatud: 13 Nov 2012, 22:40
Postitas xjan
Kogu komplekt on uus ja karpides. Tehniline joonis on mingi teise tootja lehelt, kuid mälu järgi oli samasugune ka antud komplekti kasutusjuhendis, muus osas tehnilist poolt kommenteerida ei julge, kuna see pole minu valdkond. Võimalik, et see joonis pole ka tehniliselt päris õige, mille siia panin illustratsiooniks.
