M: DOUSSIE parkett
Postitatud: 29 Okt 2015, 15:28
Postitas Chrissy
Müüa ilusat eksootilist DOUSSIE parketti.
Kogus:
Pakis: 1,638 m2
Kokku: saadaval umbes 80m2
Tooteinfo:
Engineered 4mm Top Veneer
Best Grade
15.6 x 91 x RL from 300-1200mm
Pre-finished with Aluminum oxide
Natural color with 35 Gloss
HIND: 35€ ruutmeeter (originaalhind üle 60€ ruut)
CULTURALCOCTAIL@GMAIL.COM
Doussie is a beautiful orange-brown wood. It is one of most popular species that are imported into Europe. In Central and West Africa is considered a sacred and healing. Essential oils have Doussie supposedly curative effect on the human body. Doussie is very stable.
Appearance:
The sapwood of doussie is pale-yellow to white, while the heartwood ranges from light brown to reddish brown. The grain is straight and slightly interlocked. The wood has a medium luster, and the texture is somewhat coarse.
Properties:
Doussie is very hard and durable, and it has excellent resistance to attack by termites. The wood remains smooth under friction. Doussie shows only small movement with time.
Janka Hardness: 1810
As a flooring option, doussie’s hardness is over twice that of southern yellow pine, noticably harder than hard maple, almost identical to hickory or pecan, and about three quarters as hard as santos mahogany.
Workability:
Doussie has good machining qualities, and it sands to a smooth surface. When nailed, it has good holding ability. The wood has satisfactory staining and polishing ability due to yellow deposits in pores.
Principal Uses:
Because doussie wood is so hard and strong, it is among the most valuable exotic hardwood species. Its uses include fine flooring, furniture, decking, stair rails, and construction.
Numerical Strength Properties and Data:
Bending Strength = 19,175 psi or 1,348 kg/cm2
Density = 49 Lbs/Ft3 or 785 kg/m3
Janka Hardness = 1810
Hardness = 2,103 lbs. or 953 kg
Impact Strength = 30
Maximum Crushing Strength = 10,459 psi or 735 kg/cm2
Shearing Strength = 1941 psi or 136 kg/cm2
Stiffness = 1,888,000 psi or 1,132,000 kg/cm2
Specific Gravity = 0.62
Work to Maximum Load = 11 inch-lbs/in3 or 0.77 cm-kg/cm3
Weight = 48 Lbs/Ft3 or 769 kg/m3
Radial Shrinkage = 2%
Tangential Shrinkage = 4%
Volumetric Shrinkage = 8%
T/R Ration =
Fiber Saturation Point = 19%
General Characteristics = Wood golden brown to light red brown, sometimes with darker veins. The heartwood is light brown in color, turning reddish-brown upon exposure, and is sharply demarcated from the sapwood.
Grain = Straight or interlocked
Texture = Moderately Coarse, even texture
Movement in Service = Low
Photosensitivity = Low
