M/V: Milwaukee Kango 950K perforaator
Postitatud: 07 Sept 2014, 19:38
Postitas MartinQ
Kasutatud.
Heas korras.
650€ (uue hind 1250€)
Asub Tallinnas
581 360 17
Milwaukee Kango 950K 10 kg drilling and breaking hammer K - Hex type fitting
•20 Joules energy for best in class breaking performance (blow rate 975 - 1950 bpm)
•1700 watt motor, best in class with plenty in reserve for the toughest applications
•Ideal for use with generators
•DIGITRONIC fullwave electronics for precise power adjustment to application
•3 handles - all with AVS (Anti-vibration System) and soft grip for comfortable and less tiring use
•In-line motor design for more comfort in below waist applications
•Automatic lubrication system for longer life
•Drilling capacity with solid bits 28-50 mm, with core bits 45-150 mm
•Drilling capacity with tunnel bits 50-80 mm
•Vibration level (3-axis) drilling into concrete/breaking 12.5/11.0 m/s2
•3 Year Warranty on tool
Supplied equipment:-
•6 mtr cable
•Front spade handle
•Straight handle
•Dust shield
•Grease
•Carrying case
