Uudiseid korstna maailmast
Postitatud: 22 Mai 2014, 15:02
Practical and Logical.
The cover made out of stainless steel protects the inside of the filter from all weather conditions. It also protects the outside from the generated high voltage.
The electronic control panel and the insolator including the electrode is mounted to the support panel. The electrode is inserted through the T-piece on top of the chimney flue.
The electrode is 1.6m long and has a diameter of 10mm. Diameter and flue draft are not been affected by mounting filter on top of the chimney.
