Minul igatahes selline töötab.Sobib ideaalselt ka radiaatorküttele.
Geothermal heat pump
Model& GSWW10/H
Heat capacity 10200W
Nominal voltage 400V~
Nominal frequency 50Hz
Rated Power& 3600W
Rated Current& 5.80A
Max. input power 6690W
Max. Current& 10.8A
Refrigerant& R134a
Filling weight 3000g Water flow
inside 0.9m3/h
outside 2.2m3/h
Max. operating pressure& 3.0Mpa
Net weight 125kg
ja mis peamine on hind!
