Technical Data:
Power Supply 230 Vac±10%,50/60HZ / 110 Vac Optional
The Max Switch power 3600W
Internal Sensor Setting Range 5°C-35°C (programmable) (factory setting: 25°C)
Internal Sensor Measurement Range 0-40 °C
Internal Sensor Measurement Range 0-90 °C
Display Type touch lcd screen, display area size: 60 x 45 mm
Inside Sensor NTC B=3380 10k @25degrees Celsius
Extra Sensor Length=3M NTC B=3380 10k @25degrees Celsius
Setting Unit 0.5°C / step
Indication Accuracy 0.1°C
Weight 180 g/piece
Shell ABS+PC fire retardant
Backlight Type white or blue
Working Mode On/Off,Floating,Modulating or Multi-fuctions
Certification CE
Sensor Internal or External
Programmability Non-programmable & Programmable (5+2 days,6+1 days, 7 days 4 periods)
Inner Box Size 100 x 100 x 60 mm
Main Features:
Setting daily 4 periods of time and the setting temperature.
The selection for manual control or automatic periods of time control.
The application of electric heating of the electric heating equipment and Water heating system of electric heating re actuator control.
Easy operation and utility.
Touch screen input, Nice looking and easy-cleaning.
Kinds of periods of time modes. 5+2 / 6+1 / 7days
The maximum switch power is 3600W.
The wide voltage input: AC75-250V 50Hz/60Hz
Mini size junction box. It is suitable for the entire world.
The clock continues when power fail and it won't affect the period of time settings.
Flame retardant and safe.
Extra over heating sensor label length: 3 meters
